verify toll bypass is working
How can I check test calls from last night were routed correctly for toll by pass?
Randall
Re: verify toll bypass is working
CDR records, if you can make a call now use some debugs
otherwise look at a CUCM trace
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi The calls were made 15:00 local time in China so I just need to check to see if the calls came through my local gw
can't I do it through cdr reports?
Randall
yes, i did mention them in my previous post in case you missed that
java
java
sorry, I need more detailed info
RC
127
