Verizon Business SIP Trunk config ?
In general with a Verizon Buisness SIP Trunk is a MTP resource required for every call? So planning for 80 calls means you should have 80 hardware IOS MTP resources avail? We noticed without MTP resources we can't transfer calls. Using CallManager 7.0(2), CUBE 12.4(20T), UCCX 7.0(1)SR1.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00808b6ca6.shtml
1 REPLY
Re: Verizon Business SIP Trunk config ?
As you see in your document since version 5.0 no need MTP for SIP trunk.
Easy way to do it:
CUCM -- SIP trunk/or H323 -- CUBE -- SIP -- SIP provider
Sample config from CUBE:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
sip-ua
credentials username xxx password yyy realm sip.provider
authentication username xxx password yyy
registrar dns:sip.provider expires 3600
sip-server dns:sip.provider
Remember you have to add dial-peer on CUBE and SIP trunk from CUCM to CUBE.
474
