Version conflict in Callmanager 5.1(3) while adding a node
We are trying to add a subsequent node to a Callmanager 5.1(3) Cluster.
The first node is upgraded to 5.1(3)-2000, and when we try to install a node from DVD media with version 5.1(3)-1000 it states that the node cannot be added because the Publisher is a different version.
What's the correct procedure to add the node?
1 ACCEPTED SOLUTION
Re: Version conflict in Callmanager 5.1(3) while adding a node
during the install you get the option to apply a SR or ES, you need to download the upgrade file to 5.1(3)-2000 and apply it during the install of the SUB
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
106
