Versions
Is it possible to equal both versions (active and inactive) of CCM on installed server (CCM 5.X or CCM 6.X) by just using copy command?
1 REPLY
Re: Versions
no, it's not possible to do that just using something as simple as a copy command
java
if this helps, please rate
java
www.cisco.com/go/pdi
87
