Very Simple Lab for Testing Cisco IP Phones
I wish to setup a very basic lab for testing Cisco IP phones. All I wanted is to connect two Cisco IP phones together via a Cisco router. Configure the router and be able to make some test calls.
Is this possible? What models of Cisco routers can I use to set this lab up? Do I need any particular IOS or other software running on this router to be able to setup this lab? Do I need any special cards on the router?
Are there any sample Cisco router configs that I can use?
Many thanks.
Re: Very Simple Lab for Testing Cisco IP Phones
hi,
I found sample config.check it-
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Here explanation of IOS versions
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps10587/ps10591/ps10621/qa_c67_561940.html
You need 18xx,19xx,28xx,29xx with IOS early 15.x IP Voice or 15.x UC
Don't need any cards.
Hope it helps.
Mike
here more detailed guide-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
And
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
2844
