( VERY URGENT !!! ) ATA 187 with CME 9.0 issue
Hi Team
I'm attaching the config template of the CME with this request .
There is an ATA 187 and CME (having OS 9.0 beta version that supports ATA 187).
The phones connected to the ATA 187 are having only the busy tone .
Kindly please send me the debug commands that can help me in trouble shooting the issue .
Please consider his request as highly urgent and critical .
Unni
00966506288662
1 ACCEPTED SOLUTION
The newest IOS has some toll frout aplication that blocks incoming calls for any untrusted ip so the exemple below may help, if not please collect
-debug ccsip message
-debug voice ccapi inout
Please also collect:
sh voice register pool all
Check if the ATA is full register.
Please attach the debugs and outputs and we will be more than glad to help!!
Bronze
add:
voice service voip
ip address trusted list
ipv4
eg
voice service voip
ipv4 10.3.0.0 255.255.0.0
good luck
I tried ATA 187 with CME 9.0
I think Cisco still didn't give support for ATA 187 on CME 9.0 that I found the same error in "debug tftp events" appear for both CME 7 and CME 9
the debug say that the ATA successfuly got the cnf.xml configuration file but can't find the CTLSEPata.mac.add.tlv
I don't know why ATA is looking for CTL.tlv file,, but it is the case for both CME 7 and CME 9
For the trusted list command,, I don't use it and all IP Phones can call each other and can call PSTN
Haitham
Hi hythamhadad
You can find the debug and sh command outputs by following the below link :
https://supportforums.cisco.com/message/3517011#3517011
Thanks a ton in advance !
Unni
562
