VG 202 MGCP no dialtone
I'm configuring a VG202 using the MGCP protocol. However, I get no dialtone.
CUCM = 192.168.8.11
show running-config (VG202):
VG202-1#show run
Building configuration...
Current configuration : 1764 bytes
version 12.4
no service pad
hostname VG202-1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ipv6 cef
voice service voip
voice-card 0
username fcs privilege 15 secret 5 $1$YgWh$LpHoJnoGfLkOCM8sbXO8h.
archive
log config
  hidekeys
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/0
cptone BE
voice-port 0/1
cptone BE
ccm-manager redundant-host 192.168.8.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.8.11
ccm-manager config
mgcp
mgcp call-agent 192.168.8.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 gateway force
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 900 pots
service mgcpapp
port 0/0
dial-peer voice 901 pots
service mgcpapp
port 0/1
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login
exception data-corruption buffer truncate
end
show mgcp:
VG202-1#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 192.168.8.11 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
                         hs-package rtp-package atm-package ms-package dt-package
                         mt-package sst-package md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is ENABLED
MGCP T.38 Fax ECM is ENABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bound to interface FastEthernet0/0
MGCP media bound to interface FastEthernet0/0
MGCP Upspeed payload type for G711ulaw: 0,  G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Static payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
show ccm:
VG202-1#show ccm
MGCP Domain Name: VG202-1.genk.be
Priority        Status                   Host
Primary         Registering with CM      192.168.8.11
First Backup    Duplicate of Primary     192.168.8.11
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            01:23:38 UTC Mar 1 2002 (elapsed time: 00:08:23)
Last MGCP traffic time:         01:31:47 UTC Mar 1 2002 (elapsed time: 00:00:14)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 0
          Download Failed              : 0
        Configuration Attempted        : 0
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command:
FAX mode: disable
Configuration Error History:
On the CUCM the gateway is configured, and has a line associated with the port I want to use. Can anybody point me to what is wrong?
1 ACCEPTED SOLUTION
VIP Super Bronze
VG202-1#show ccm
Second Backup   None
Your vg202 ports are not registered with the CUCM.  The mgcp domain name shows vg202-1.genke.be...is this what is configured in cucm?
Your vg202 hostname doesnt match this...your hostname including if you have ip domain name configured needs to match what ypu have in cucm..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
VG202-1#show ccm
Second Backup   None
Hi aokanlawon.
I had in CUCM put VG202-01.genk.be, so a small typo I was looking over each time. Thanks!
Thanks!
346
