12-12-2007 07:41 AM - edited 03-15-2019 07:45 AM
Hi, i have a callmanager 4.3(1) where i have registered a VG 224 using SCCP protocol. The customer wants that the analog phones that are managed by the VG have distinctive ringing when the call comes from the PSTN (off net) and the call come from a callmanager extension (On net). Do anyone have configured this once.
Thanks in advanced
Jose
12-12-2007 01:47 PM
I heard that vg 224 doesn't support this feature. Is that true?
12-12-2007 02:10 PM
Probably not the answer that you are looking for, but it does not appear that this feature is supported. Unfortunately, I'm unable to find any documentation which would indicate otherwise.
Below is the link to the VG224 datasheet, and no reference is made to this under the supplimentary services:-
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a00801d87f6.html
Allan.
12-12-2007 02:24 PM
Oh that is not a good notice haha ...well i also couldn't find information about how to do it.
Well, thanks for your help Allan
Jose
