Community Member
VG 224 - Distinctive Ringing?
Hi, i have a callmanager 4.3(1) where i have registered a VG 224 using SCCP protocol. The customer wants that the analog phones that are managed by the VG have distinctive ringing when the call comes from the PSTN (off net) and the call come from a callmanager extension (On net). Do anyone have configured this once.
Thanks in advanced
Jose
Community Member
Re: VG 224 - Distinctive Ringing?
I heard that vg 224 doesn't support this feature. Is that true?
Probably not the answer that you are looking for, but it does not appear that this feature is supported. Unfortunately, I'm unable to find any documentation which would indicate otherwise.
Below is the link to the VG224 datasheet, and no reference is made to this under the supplimentary services:-
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a00801d87f6.html
Allan.
Community Member
Oh that is not a good notice haha ...well i also couldn't find information about how to do it.
Well, thanks for your help Allan
Jose
146
