VG 224
I have 2 VG224 gateways in my network. The first one is working fine, i'm having issues with the second one.
After troubleshooting the unit i found out the the voltage i'm getting for voice ports is very low. It's aroung 10V per port.
I remember i had similar issue long time ago but i don't really remember what the command i used to bring the port voltage up. Any help?
Bronze
Re: VG 224
Use the command “alt-battery-feed feed2” to bring the port voltage up.
Re: VG 224
Is this a voice-port command? I don't see it as an option under commands.
thanks
Re: VG 224
it's a hidden command. try putting it in, and the router should take it.
-nick
Re: VG 224
this hidden cisco command doesnt work under my vg224 fxs port
vg ios : vg224-i6s-mz.124-5b.bin
Re: VG 224
It'll be accepted after upgrading your ios
But this command won't raise your output volt to -48 v, only it'll be about 38 or 39, so you may need an extra transformer on the needed line to have more voltage
thanks
406
