VG202/204 GET-VPN
Do VG202/204 supports GET-VPN encryption?
Thanks in advance
Tomek
1 REPLY
VG202/204 GET-VPN
Hello Tomasz,
GETVPN is avalable only for routers according to information on CCO:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps7180/product_data_sheet0900aecd80582067.html and VG2xx are not supported.
Voice adapters or gateways should be located behind the GETVPN node (excluding situation where VG function is combined on ISR router acting as GETVPN node, then IOS with VSEC bundle is required),
Regards/Piotr
311
