vg202 and faxing using cucm to sip provider
I have been having a few issues with getting faxing working to sip provider. Setup is as follows..
Fax <> vg202 <> sccp <> cucm 8.6 <> sip <> bt sip service
Basically i had a situation where the vg202 was configured for fax passthrough g.711ulaw and i created a region for g7.11 for vg202 im ccm to sip.
Managed to get outbound faxing working but inbound would not. Speaking to bt i think they support g711alaw and t.38.. I had no luck with t.38 so decided on g.711alaw passthrough and this time inbound faxing was working but outbound failed??!!
Speaking to bt on some of the debugging they say i am still requesting ulaw howevevr vg202 is not configured for this? Maybe the sip trunk is requesting this?
The fax is a brother.. I did look into reducing he baud rate but no option for it.. Any ideas of experiances of this would be appreciated..
Is sccp the way forward here?
Matt
Hall of Fame Super Silver
Matt,
You had no lock with T.38 as protocol based T.38 is not supported with SCCP, you need to either use H323/SIP or MGCP.  SCCP only support NSE based T.38 which is Cisco proprietary and not supported by any carriers. T.38 is the recommended faxing protocol, especially over SIP trunks so my suggestion would to convert the VG202 to either SIP or H323 and implement protocol based T.38. Also, make sure your CUBE configuration matches the T.38 configuration.
HTH,
Chris
Re: vg202 and faxing using cucm to sip provider
Hi Chris,
Thanks for the feedback will test with MGCP first. We have no cube
involved our trunk is direct from ccm to the provider as the provider is
within our mpls cloud..
Matt
On 13 February 2012 22:46, cderen <
456
