VG202 with call manager 7
I am trying to setup the VG202 to work with call manager. So far I can make calls from the VOIP telephones registered with the call manager to the phone connected to the VG202. When I talk into the VOIP telephone I can hear voice on the Analog telephone, but when I talk into the Analog phone I cannot hear the voice in the VOIP telephones. Also I can't dial anything from the Analog telephone connected to the VG202. Below is the config I have setup on the VG202. Can anyone please show me what i am doing wrong?
Building configuration...
Current configuration : 1550 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip routing
no ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice rtp send-recv
voice service pots
voice service voip
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback cisco
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address dhcp
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
caller-id enable type 1
voice-port 0/1
ccm-manager fax protocol cisco
ccm-manager config server 10.10.0.8
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
mgcp fax t38 ecm
sccp ccm 10.10.0.8 identifier 2 version 4.1
sccp ccm 10.10.0.9 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 1000 pots
dial-peer voice 999000 pots
service stcapp
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
login
exception data-corruption buffer truncate
end
1 ACCEPTED SOLUTION
Re: VG202 with call manager 7
You have following in the config that needs to be removed:
no ip routing
but before you remove that aka configure "ip routing" you must
add a default route (else you'll lose IP connectivity to the box!)
some thing like...
ip route 0.0.0.0 0.0.0.0
that will fix it.
1 REPLY
no ip routing
some thing like...
that will fix it.
1899
