08-08-2012 08:14 AM - edited 03-16-2019 12:36 PM
I have an installation with a Cisco CUCM 7.1.5, and VG204 runing 12.4(22)T5 and declare as a SCCP Gateway. We connect a fax or an Intercom system (castel) to the VG204 port 0/0, the intercom call an iPPhone, when the ipphone hangs up the intercom stay on hook and after a few seconds we got the message "the number you try to reach is not ..." and after that a busy tone and then the system hangs up.
Do you have an idea on how to configure the VG204 or the CUCM for have this infrastructure working? I tried to replace the intercom system by an analog phone and i have the same issue, the analog phone do not hangs up properly.
Solved! Go to Solution.
08-13-2012 12:42 AM
I finally found a solution for my problem, if it could help someone here is the solution i found.
In the dial peer concerned by the Intercom you should use those commands :
no tone dialtone remote-onhook
tone busytone remote-onhook
Instead of having a tone for a new cal I have a busytone, my intercom understand that the call is over and hang up.
08-13-2012 12:42 AM
