VG204 Connectivity
I have an issue where a credit card terminal via a VG204 SCCP won't connect. I keep getting a communication error message. I am able to hook up an analog telephone and dial to where ever I want and i'm able to receive a call as well. I have this working at other sites using the same configuration, is there anything that I can tweak on this particular VG204? What is equally confusing is that the credit card machine will work at this site with an ATA186. The IOS is version 15.1 but I don't think that has any bearing. HELP ANYONE???
Check the fax/modem relay
Check the fax/modem relay settings in CUCM, and make sure they are off/pass-through.
Credit card machines (and also franking machines) tend to be very picky about their phone lines. They don't like down-speeding when they can't do something like V.34/V.90 speeds (Which is impossible on a VoIP line), so try forcing the machine to run at a slower speed e.g. V.32. (Unfortunately you can't always do this, so you then get stuck and have to install an analogue exchagne line:-(  )
GTG
Please rate all helpful posts.
Thanks Gordon, everything
Thanks Gordon, everything looks good on the CUCM and other VG devices are working fine at other sites. I guess this particular cc machine is extra touchy.
57
