01-11-2012 01:16 PM - edited 03-16-2019 08:57 AM
I am testing 2 analog ports through a VG224. I program two ports and assign dn's to each port. When I try to draw dial tone from either device I get a busy signal at the handset. I went directly to the punch down that terminates to the vg's and get the same thing.
Any ideas??
Thanks so much for responding....
01-11-2012 01:43 PM
Maybe (have to gues as you did not specify), you're using MGCP or SCCP, and the device is not registered to CM.
01-11-2012 01:45 PM
Using SCCP. I do see the port registered to CUCM.
01-11-2012 01:47 PM
Do the SCCP registration checks on the VG224 too.
01-11-2012 01:51 PM
I do sho sccp on the vg and get the below results. It's port 0 & 6 that I'm using.
hvb-vg224-127#sho sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
IPv4 Address: 10.16.19.127
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.32.19.19, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 13
Trustpoint: N/A
Call Manager: 10.16.19.14, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 12
Trustpoint: N/A
Call Manager: 10.16.19.13, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 11
Trustpoint: N/A
Call Manager: 10.16.19.19, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 30
Trustpoint: N/A
Alg_Phone Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 10.32.19.19, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9401
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: ilbc, Maximum Packetization Period: 120
Active Call Manager: 10.16.19.13, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9402
Active Call Manager: 10.16.19.14, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9403
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9404
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9405
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Device Name: AN5FB9EE5CD9406
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9407
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9408
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9409
Active Call Manager: 10.16.19.19, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940A
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940B
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940C
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940D
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940E
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD940F
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9410
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9411
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9412
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9413
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9414
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9415
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9416
TCP Link Status: NOT_CONNECTED, Device Name: AN5FB9EE5CD9417
TCP Link Status: CONNECTED, Device Name: AN5FB9EE5CD9400
hvb-vg224-127#
01-11-2012 01:55 PM
Maybe reduce the number of CMs to register to, or set priorities, or resynch cluster members
The idea being eliminating any
CCM_REGISTER_FAILED
01-11-2012 02:00 PM
I could set priorities, but this wouldn't have anything to do with busy signal, correct?
01-11-2012 02:05 PM
My thinking, and I can be wrong, is that the VG224 got confused by the registration failures, and unable to operate correctly.
You can try updating IOS if in the mood.
