Hi all -
Running CUCM 7.1.3 and I'm trying to set up a BAT install of a VG224 SCCP gateway. I can get this to work every time with just a basic BAT CSV file(includes MAC, Description, Slot, Subunit,Port Directory Number, Port Number, Port Description) which is good. However, we have about 30 VG224's to install and I need to ensure that the BAT file includes the ASCII, Alerting and Descrition and Mask information for line 1. When I add these columns to the csv file I get an error (which changes slightly as I work on adjusting the column header or contents (error now is ---> Ascii text label 1(Record Number 1) 2004 ASCII Line Text Label is blank <--- )
I'm not quite sure what I have missed. I believe the CSV file is right but clearly this is not working.
Does anyone have a CSV format for an SCCP VG-224 BAT load that includes all the alerting and name information that works or could someone point me in the right direction? I have gone through the docs but I just cannot locate the answer.
Les
