VG224 and CME
This is the first time getting VG224 to work with CME.
I read the doc on it and have created ephone-dn's for each of the ports. I have also configured ephone x, but for the MAC address do you do the same as it would be seen within CCM of 001A61CA5EC2, but remove the first 2 characters and add to the end of the port.
1A61CA5EC201 for port 1, and so on?
Would it be better to run in SCCP or H323 for connecting faxes to it?
Thanks in advance
Green
Re: VG224 and CME
For faxes my recommendation will be H323 since it its fully tested.
SCCP can work but you may encountered some problems.
Re: VG224 and CME
Thanks for the response, but is how I set it up in CME the correct way?
I assume that you put dial-peers on the VG to point to CME and on CME put voip dial-peers for the fax numbers to point the the VG?
VG
dial-peer voice 100 voip
destination-pattern 9T
session target ipv4:CME IP ADDRESS
codec G711ulaw
no vad
modem passthrough nse codec g711ulaw
fax rate disable
dial-peer voice 101 voip
incoming-called number (extension range)
CME
destination-pattern (extension range)
session-target ipv4:(VG IP Address)
fax rate disable
no vad
g711ulaw
778
