VG224 and CMM5.0
What is the right steps I should configure VG224 to register with the CCM5.0?
I'm not familiar with VG224. Do I need to manually configure the extension on the VG224? Or Can I deploy all extensions by using CCM?
Please recommend/advise me.
Thot
1 REPLY
Re: VG224 and CMM5.0
what are you going to use?
MGCP? SCCP? H323?
if you look under CCO there are several configuration examples depending on what protocol you're going to use
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
112
