Community Member
VG224 and MGCP-controlled PRI
i have
- a cisco 2951 with 2 E1 interfaces controlled by a cucm 8.6
- a VG224 controlled by MGCP
I have many (many) troubles with faxes inbound. They seem to work randomly
Current setup is with modem passthrough and NSE, on both sides I have:
voice service voip
fax protocol none
modem passthrough voip mode nse
mgcp modem passthrough voip mode nse codec g711alaw
I would like to have some feedback on this configuration, and/or suggestion about different setup...
Thanks in advance
Green
On the 2951 ensure that the clocking for the E1 TDM is correct.
You need something like this:-
But with your card numbers etc
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
This has to be correct for faxing.
Veify with
show network
Look to see that the clocking is from the E1 line.
Alex
Regards, Alex. Please rate useful posts.
Community Member
The clock source comes from the E1:
mgw01#sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          E1 0/0/0        GOOD            E1
     2          E1 0/2/0        GOOD            E1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          E1 0/0/0        GOOD            E1
Green
Can you look at these commands alter and apply to your
gateways
mgcp fax t.38 inhibit
no ccm-manager fax protocol
mgcp modem passthrough voip codec g711ulaw
!if you have more than 1 IP interface
!then bind 1 to the MGCP, using
!your interface number
mgcp bind control source-interface FastEthernet0
mgcp bind media source-interface FastEthernet0
Also check on the gateways in CUCM that
you have FAX RELAY unchecked
Alex
Community Member
I have all those commands applied on both gateways (2951 and vg224) and I've also checked on CUCM web page that, on both gateways:
- modem passthrough: enable
- t.38 fax relay: disable
- cisco fax relay: disable
now i've resetted the VG just to be sure that I have some configuration lock...
but it's still not working
btw thanks a lot 4 your help...
Green
Looking at this link
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/pt.html#wp1088980
SUMMARY STEPS
1. mgcp package-capability rtp-package
2. mgcp modem passthrough voip mode nse
3. mgcp modem passthrough voip codec {g711ulaw | g711alaw}
4. mgcp modem passthrough voip redundancy [sample-duration [10 | 20]] [maximum-sessions sessions]
5. mgcp timer nse-response t38 time
6. mgcp fax t.38 inhibit
7. exit
8. show running-config
9. show mgcp
Alex
Community Member
no way.. I did exactly the same setup without the
mgcp-timer nse-responde t38 time
sample-duration
now i've added these two lines but the situation is the same as usual.. if i add the voip redundancy on the vg224 the quality of the answer tone seems very poor and choppy...
570
