11-05-2010 09:25 AM - edited 03-16-2019 01:45 AM
Hello Community,
I just experienced an issue where an Analog phone connected to a VG224 (configured to use SCCP) was having its time reset on its display. The time on the analog phone was being set manually through the phone interface and then when the phone would make an outbound call or receive an inbound call the time on it would reset. In doing a "show clock" on the VG224 it was connected to I discovered that the phone's time matched the VG224's time. I thought there was no way the time would be passed to the phone from the VG but it appears that it was. To resolve the issue I set NTP and the timezone on the VG224 appropriately and it fixed the issue. Does anyone know how or why the analog phone would be getting time information from the VG? Has anyone else out there experienced this issue?
Thanks!
Solved! Go to Solution.
11-08-2010 01:51 PM
The phone takes date and time via caller ID. That is a common feature in North America, Bellcore standard.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800a9a49.shtml
11-08-2010 01:34 PM
hmm..interesting....never seen this where analog phone connected via
copper pair to GW's FXS port would get the time info from the GW.
Thinking perhaps phone was somehow using the callerID info which
does has the ability to pass date/time info.
Does it occur if u disable callerid under the FXS port?
Curious, what make/model these phones are?
11-08-2010 01:51 PM
11-08-2010 02:10 PM
Thank you both for your replies. I did not try disabling the caller ID as part of the troubleshooting and the phones mostly being used were some model of VTECH phones. It looks like that link that Paolo included contains information about the phone getting time from the router so thank you for the link Paolo. I believe that clears it up.
Thanks again!
