VG224 busy state and redirect
Paul Austin
Level 4
Level 4
Hi All, Got a VG224 in H323 mode that takes calls directly from callmanager OR via the PSTN through a router configured as CME. Trouble I have is that if a call comes to a port through the PSTN on the gateway and then via dial peers to the VG224 it all works fine BUT if another call comes along whilst the 1st one is still active, we get busy tone but I need to do a call forward busy back out to something else - cant find any suitable command that will achive this - any ideas please?
Many Thanks
7 Replies 7
boris.kudr
Hi Paul,
Since it's a standalone gateway, I beleive you configured it as a H323 gateway or trunk in CUCM.
You can enable call hunting on busy condition via Service Settings, but you will have to add a second route group (with appropriate translation and members) into the route list currently used to route calls towards VG.
As for the CME, you should add "voice hunt user-busy" and a second dial-peer with the same destination pattern and appropriate target/translation to continue routing on busy disconnect cause received from the VG.
Boris
You should be able to add a second set of dial-peers on the VG224 translating the number and pointing back CUCM.
HTH,
Chris
I've created a second dial-peer (voip type) that has a preference of 2 that points back to the cucm environment and voice hunt user-busy command on the VG224, the cucm has a cti port that has a call forward all to voicemail but all I get is a busy tone when the second call is made.
Can you post "debug voice dialpeer", does the CSS assigned to the GW have access to the parition of this cti port?  Is sigDigits defined properly?
Chris
The call comes directly into a cme then onwards to a h323 vg224. The call will go out on a port ok but I need to send the 2nd call to cucm
Paul Austin
Field Engineer
Capita IT Services
Ellismuir Way
Tannochside Park
Uddingston
Glasgow
G71 5PW
07769 165019
Paul.austin@capita.co.uk
www.capita-its.co.uk
Part of The Capita Group plc
www.capita.co.uk
Paul,
On the CME can you try adding something like these dial peers
as CAC to the VG & CUCM
dial-peer voice 1000 voip
desc *** PEER TO VG224 ***
pref 1
max-conn 1
destination-pattern 5577
session target ipv4:192.168.1.100
dial-peer voice 2000 voip
desc *** PEER TO CUCM ***
pref 2
session target ipv4:192.168.1.200
If DP 1000 already has 1 call it should busied and  I think the DP 2000 will be tried as a PREF 2
Worth a go to test anyway.
Alex
Regards, Alex. Please rate useful posts.
Hi Alex, Still no joy - its quite frustrating as I am sure it should work. Thanks anyhow.
