VG224 Cabling Distance
Does anyone know what is the cabling distance limitation on VG224 .I have a customer who has cabling going to 11th floor from CO and then coming back down for fax machines to 1st FL.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: VG224 Cabling Distance
11 floors at 5 (exaggerated) meters each equals 55m, you are below the maximum by a factor of 20.
1 REPLY
222
