VG224 - Calls are dropping after 5 or 20 seconds
I am looking at a pointer to troubleshoot this problem. The VG224 is running IOS version vg224-i6s-mz.124-2.T6.bin and is setup as H323 Gateway.
interface FastEthernet0/0
description CN,DX,E,Connected to xs9521dx001 FastEthernet1/0/44
ip address 10.83.187.4 255.255.255.0
no ip redirects
no ip proxy-arp
duplex full
speed 100
no snmp trap link-status
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.83.187.4
Re: VG224 - Calls are dropping after 5 or 20 seconds
Do you have caller ID enabled. If so turn it off and see if it changes. I had the same problem and it was a Bug that has been around for years that Cisco still has not fixed. If you need that feature then go back to 12.4.6T11. I did not write down the Bug ID....but if it is the problem then you can look it up.
If it helps do not forget to rate.....:-)
This is the config and it is pretty much teh same for all 24 ports:
voice-port 2/0
no supervisory disconnect lcfo
echo-cancel coverage 32
cptone AU
timeouts call-disconnect 0
timeouts ringing 360
timeouts wait-release 5
impedance complex1
caller-id enable
Yes caller-id is enabled. But this customer says he has had this config for over a year and the problem only started a couple of days ago. So he doesn't want to turn-off caller id.
He also said that he rebooted teh VG224 and that made no difference to the problem.
365
