Community Member
VG224: Can't Password Reset
I have a VG224 for which I need to reset/recover the password.  I haven't been able to find any Cisco documentation on how to do it.  I have tried the normal stuff you'd do on other Cisco devices but it's not doing it.
I tried using the break key while booting up, and pressing the 'esc' key while booting up (as Cisco says you should do for the VG248--although I learned this is not even based on the IOS, so somewhat different to the VG224).
So can someone help me on resetting the password?  I don't mind losing configurations either.
Thanks.
Re: VG224: Can't Password Reset
There are two types of voice gateways (VG 224 and VG248). The following
url(s) cover password recovery for both of them:
For VG224 (It is like any other IOS device)
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_password_recovery09186a008
0093e26.shtml
For VG248
009440c.shtml
Please let me know if you have any questions on the above.
regards
Armando
Community Member
No, it just doesn't work.
I tried all the break sequences listed here that applied to my situation:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
I even tried simulating the break sequence as suggested on the link above.
It might also help noting that I see no boot up output while the device is booting--unlike all the other cisco devices I've used thus far.  The only output I see on my terminal is 'press return to get started', and that's about 40secs after turning on the device.
so you tried CTRL+BREAK or CTRL+Break+F6 ?
that should take you to rommon where you can change the register.
can you take a show line?, I have only seen that before when connected to the Aux port instead of the console port,
can you please verify?
Community Member
Oh wow, I feel so dumb.
When I typed the sh line command and I saw aux 9600/9600 etc., I couldn't believe it.  I was indeed plugged into the aux, I had 'verified' this at least twice already.
Thanks so much for the help Armando, no wonder I wasn't getting any text during bootup.  This will now hunt me in my sleep.
Community Member
Thanks for the help, break wasnt taking on my end until I hit it with a 'f6'.
11789
