11-06-2009 06:36 PM - edited 03-15-2019 08:23 PM
HI, 'm running a vg224 directly connected to a service provider h.323 trunk, calls works well, ut i can't send caller id; i tried using clid command and translation rules, but it doesn't work.
Solved! Go to Solution.
11-07-2009 10:53 AM
Send clid where ?
11-06-2009 09:43 PM
Try changing the "cptone" under the voice-port.
MK
11-07-2009 03:19 AM
No difference
11-07-2009 10:53 AM
Send clid where ?
11-08-2009 01:34 PM
Hi, i used a ccme and forwards all calls from vg224 to it. Later i configured caller id on ccmme and now is working fine.
11-08-2009 01:41 PM
Very good, next step configure ports in SCCP mode to enable many features, that your users may like.
