VG224 clid on h.323
HI, 'm running a vg224 directly connected to a service provider h.323 trunk, calls works well, ut i can't send caller id; i tried using clid command and translation rules, but it doesn't work.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: VG224 clid on h.323
Send clid where ?
Silver
Try changing the "cptone" under the voice-port.
MK
No difference
Send clid where ?
Hi, i used a ccme and forwards all calls from vg224 to it. Later i configured caller id on ccmme and now is working fine.
Very good, next step configure ports in SCCP mode to enable many features, that your users may like.
223
