VG224 code upgrade
Can I go from
Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 15.0(1)M1, RELEASE SOF
TWARE (fc1)
To version 15.1.4M6 or is there a couple versions i have to upgrade to first before i go to 15.1.4m6.
Thank You.
VIP Purple
VG224 code upgrade
Hi Chuck,
you can directly upgrade to 15.1.4M7 from 15.0(1)M1
http://software.cisco.com/download/release.html?mdfid=278714890&flowid=5808&softwareid=280805680&release=15.1.4M7&relind=AVAILABLE&rellifecycle=MD&reltype=latest
the DRAM and Flash requirements remain same 128/64.
regds,
aman
Hall of Fame Super Silver
VG224 code upgrade
Go with what Aman recommends (+5), 15.1.4M7 is the latest supported version for VG224 due to its memory capacity.
HTH,
Chris
Re:VG224 code upgrade
Thank you
Sent from Cisco Technical Support Android App
285
