VG224 configuration with CUCM 6.1
zzbronski
I have installed a vg224 voice gateway along with our cucm6.1 and have been unable to get a analog phone to work with it. The vg224 has been entered into the cm administration under gateways with sccp. I have attached a analog phone to the vg224 and configured it in the cm adminstration with a number assigned. What else am I missing to get this to work. I have only had experience with the older vg248 which was not ios based.
kelvin.blair
Level 5
Level 5
You need to make sure you configured sccp connection on that vg224. Make sure that it is registered to call manager. Here is a sample configuration of the vg224 configured as a sccp gateway in call manager.
sccp local FastEthernet0/0
sccp ccm X.X.X.X identifier 10
sccp ccm X.X.X.X identifier 12
sccp
sccp ccm group 1
associate ccm 10 priority 1
associate ccm 12 priority 2
stcapp ccm-group 1
stcapp
dial-peer voice 1 pots
service stcapp
port 2/1
dial-peer voice 2 pots
service stcapp
port 2/2
etc....
Do a "show sccp" to see if the device is registered to call manager.
Thank you very much. That resolved the problem.
Rated Kelvin's post based on bronski's reply.
Thanks!
