VG224 configuration
I have got the VG224 and the CUCM6.1.1, i want the basic configuration on the VG224, and how do i integrate this with the CUCM. if it is gateway how it will be as a MGCP or SCCP and what will be the configuration on the VG....
Please help on this i will be greatful to you.......
Thanks & Regards
Lal Mohammad
Re: VG224 configuration
check the following link
which contain group of helpful links
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_installation_and_configuration_guides_list.html
good luck
if helpful rate
I have already gone through all those links but it does not talk about the integration wiht the CUCM, and there is no configuration for the VG224.
u can configure it as any cisco voice gate way
make the lan interface access port but put it in the vlan number that is voice vlan in ur network
and u can configure it like noraml h323 or ngcp gateway
and define it in the cucm or ccm as a gateway
then included it in ur dial plan through route pattrens route groups and so on
good luck
502
