Community Member
VG224 Distribution Panel
Guys,
I'm wondering if you can help me with the part number of the distribution panel that has to be connected to the voip gateway VG224. Does cisco have it? if no, please recommend one. I don't know whay to use.
Community Member
Re: VG224 Distribution Panel
You have your answer here:
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/prod_installation_guide09186a00801d7e59.html#wp1015991
It is a normal "distribution panel, which connects to telephones, faxes, or analog PBX equipment". No need to buy special equipment, just make the connection of the multiport analog interface to the distribution panel with the cable specified in the equipment.
Hall of Fame Super Red
Hi Walid,
Just to add a note to the good info you received from Luis. The cable you need from the VG224 is an RJ21 (Male). Normally you would be taking this 25 pair cable to a cross-connect of some type. Here are the parts you would need to connect to a 24 port rack mounted Patch Panel (without needing to terminate the cable with Bix or 110 connecting tools).
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
24 Port with RJ21 Male
http://www.cablingsys.com/iteminfo.asp?productcode=017-224M62U
These are just examples :) I have not checked pricing $$
Hope this helps!
Rob
well, if you are fancy like Rob is with the RJ11 patch panel that would be easy! But most installs I have done or have had done for me ;) were with aphenlol cables (good ones, best you can find,) then connectted to a 66 telco block. Then you can cross connect to your hearts desire anywhere in your building. Cross to other feeders, or the RJ panel like above. Get the punch down tool out!
Hey Tommer,
Ha, I wish they were all this easy as well :) You have to remember that I've been around since 1A2 Key Systems (yes that old!) when we had Amphenol Tools and made literally thousands of our own ends. Fancy is one thing I'll never be ;) (thats probably a good thing)
Take care man!
Rob
2979
