Community Member
VG224 doesn't work on CME?
Hey i'm having trouble to make voip gateways (VG224) work in my network. Here is the config from the vg224 and the cme (sh ephone)
sh ephone (CME):
IP-PBX#show ephone
ephone-1 Mac:001A.E2BC.4258 TCP socket:[3] activeLine:0 REGISTERED in SCCP ver 6
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:10.1.30.110 50098 Telecaster 7940 keepalive 43097 max_line 2
button 1: dn 1 number 250 CH1 IDLE CH2 IDLE
button 2: dn 2 number 251 CH1 IDLE CH2 IDLE
ephone-2 Mac:001A.E2BC.8D3F TCP socket:[7] activeLine:0 REGISTERED in SCCP ver 6
IP:10.1.30.112 50086 Telecaster 7940 keepalive 28897 max_line 2
button 1: dn 3 number 252 CH1 IDLE CH2 IDLE
button 2: dn 4 number 253 CH1 IDLE CH2 IDLE
Username: user2 Password: 202
ephone-3 Mac:001A.A29C.6D9F TCP socket:[2] activeLine:0 REGISTERED in SCCP ver 6
IP:10.1.30.114 49998 Telecaster 7940 keepalive 43097 max_line 2
button 1: dn 5 number 254 CH1 IDLE CH2 IDLE
button 2: dn 6 number 255 CH1 IDLE CH2 IDLE
ephone-4 Mac:C863.EE8C.0FFF TCP socket:[12] activeLine:0 REGISTERED in SCCP ver 6
IP:10.1.30.30 38696 unknown 30032 keepalive 8558 max_line 0
Ephone 4 is for the gateway and it was registered automatically, but as you notice the type is unkown and i can't make it work even after i entered it manually.
User Access Verification
Password:
CPTC-VG224>enable
Password:
CPTC-VG224#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CPTC-VG224(config)#show run
% Invalid input detected at '^' marker.
ip address 10.1.30.40 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 2/0
ren 3
disconnect-ack
loss-plan plan4
disc_pi_off
input gain 10
output attenuation 10
playout-delay minimum low
cptone HK
timing digit 53
description cflow1
music-threshold -50
bearer-cap Speech
station-id name CPTC
station-id number 1000
caller-id enable
ccm-manager config server 10.1.30.100
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.1.30.100 identifier 1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
dial-peer vice 1 pots
service stcapp
port 2/0
forward-digits all
Hey guys i also tried to add ephone to the cme with mac-address ending with 401, but it's not recognizing it.
Community Member
Re: VG224 doesn't work on CME?
please could anybody help me with the problem i'm having with my vg224?
My first message explains the problem.
Community Member
Hi Valides,
The VG224 looks ok. I suspect its your CME end. The MAC address you are showing in the ephone output for ephone 4 looks wrong.
Do a sh stcapp device summary on the VG224 and create an ephone on your CME box where the type is ANL and the MAC is the last 12 digits of the Device Name.
For example. If your show stcapp device sum returns...
VG224-1#sh stcapp device summary
Total Devices: 24
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
2/0 AN1C58C8EB3D400 IS IDLE ALG 5370 CME
2/1 AN1C58C8EB3D401 IS IDLE ALG 5371 CME
Then you CME config should be...
CCME-1#sh run | beg ephone 1
ephone 1
mac-address C58C.8EB3.D400
type anl
button 1:1
ephone 2
mac-address C58C.8EB3.D401
type anl
button 1:2
Hope that helps.
Chris
369
