VG224 DTMF CUCM 6.1(2)
last week I upgraded a CUCM server from 5.1(3) to 6.1(2).
Now I do have some issues with VG224 (doorbells).
The VG224 are connected via MGCP.
IPhone - VG224 - AnalogPhone (doorbell)
Send “0#” ---->>>
If I am connected to the doorbell - I should be able to open the door by dialing “0#”. (It worked on CUCM5)
But now I have to dial it twice to open the door. (nearly every time)
I also tried SCCP but it is the same problem.
It is the same if I use a mobile phone. So it has nothing to do with the phone firmware.
Mobile phone (PSTN) - GW(CUCM) - VG224 - AnalogPhone (doorbell)
Send “0#” ---->>>
I am using an “vg224-i6s-mz.124-11.T1.bin” image.
---------- config
stcapp ccm-group 1
stcapp
voice-card 0
>--cut--<
voice-port 2/23
cptone DE
ccm-manager redundant-host 10.97.1.60
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.97.1.60
ccm-manager config
ccm-manager config dialpeer-prefix
mgcp
mgcp call-agent 10.97.1.61 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 10.97.1.61 identifier 10
sccp
sccp ccm group 1
associate ccm 10 priority 1
dial-peer voice 99920 pots
service mgcpapp
port 2/0
dial-peer voice 99921 pots
service stcapp
port 2/1
Thanks for any help!!
Ben
1 REPLY
Silver
Re: VG224 DTMF CUCM 6.1(2)
Check the bug:
CSCsi76529: DTMF digits may not be reliably detected with DSPware 4.4.21 and newer
327
