Bronze
VG224 FAX through Modem
Hi Guys,
I have a modem which is connected to a VG224. We are trying to send Fax through that modem which is connected to another modem. It looks like modem connects the first attempt but the issue is it tries to reconnect gain and again. Please have a look at the debug in below and let me know if there's something that I can do to resolve the issue. The debug is out of the main gateway connected to the PSTN.
Nov 12 20:26:40.776 EST: ISDN Se0/2/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Nov 12 20:26:40.776 EST: ISDN Se0/2/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 9199931122
Nov 12 20:26:40.776 EST: ISDN Se0/2/1:23 Q931: Sending SETUP callref = 0x0125 callID = 0x8138 switch = primary-ni interface = User
Nov 12 20:26:40.776 EST: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0125
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Display i = 'UTILITY DESK PHO 31122'
Calling Party Number i = 0x2181, '9199931122'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '18009464644'
Nov 12 20:26:41.284 EST: ISDN Se0/2/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8125
Nov 12 20:26:42.732 EST: ISDN Se0/2/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8125
Cause i = 0x82FF - Interworking error; unspecified
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Nov 12 20:26:45.032 EST: ISDN Se0/2/1:23 Q931: RX <- CONNECT pd = 8 callref = 0x8125
Nov 12 20:26:45.032 EST: %ISDN-6-CONNECT: Interface Serial0/2/1:0 is now connected to 18009464644 N/A
Nov 12 20:26:45.032 EST: ISDN Se0/2/1:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0125
Nov 12 20:27:02.432 EST: ISDN Se0/2/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8125
Cause i = 0x8090 - Normal call clearing
Nov 12 20:27:02.432 EST: %ISDN-6-DISCONNECT: Interface Serial0/2/1:0 disconnected from 18009464644 , call lasted 17 seconds
Nov 12 20:27:02.432 EST: ISDN Se0/2/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x0125
Nov 12 20:27:02.484 EST: ISDN Se0/2/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8125
Nov 12 20:27:14.804 EST: ISDN Se0/2/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Nov 12 20:27:14.804 EST: ISDN Se0/2/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 9199931122
Nov 12 20:27:14.808 EST: ISDN Se0/2/1:23 Q931: Sending SETUP callref = 0x0126 callID = 0x8139 switch = primary-ni interface = User
Nov 12 20:27:14.808 EST: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0126
Standard = CCITT
Nov 12 20:27:15.232 EST: ISDN Se0/2/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8126
rtprtr03#
Nov 12 20:27:16.732 EST: ISDN Se0/2/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8126
rtprtr03#
Nov 12 20:27:18.764 EST: ISDN Se0/2/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0126
MK
1 REPLY
Re: VG224 FAX through Modem
Note the progress with PI of 8 instead of an alerting.  The other side of this PRI isn't connecting the call; it is throwing an inband error before ringdown.
Are you able to make other calls out this PRI that work?  If so, get 'debug isdn q931' for a good call and compare the information in the setup to see what the deviation is.
Also, what VoIP protocols are you using on the VG224 and PSTN gateway?  What fax/modem switchover method are you intending to use?
And 'sh controllers t1' on the PSTN gateway doesn't report any slips, right?
427
