vg224 for FAX
has anybody got a config for a vg224 that works with fax ? i'm being told the best config is to use H323. Also if the outside lines are on a MGCP gateway does this require additional configuration.
Re: vg224 for FAX
I use mgcp to manage mine and it works fine. here is the important part of the config
ccm-manager mgcp
ccm-manager config server X.X.X.X (where x.x.x. is callmanager publisher server ip)
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1(where x.x.x. is callmanager subscriber server ip)
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
colin
Re: vg224 for FAX
Colin
Could you possibly provide the full config for me to look through. I notice you are not using t38, does this mean you are using inband G711 codec.
329
