VG224 - Forwarding Dialled Number
I'm trying to put a Fax solution together. What I have is a 2821 Voice Gateway (MGCP) that contains the FAX DDI. I'd like to set this DDI as a CTI_Route Point that then forwards all calls to a group of 4 ports configured on the VG224 (also MGCP). These ports are connected to a Fax Server.
The problem I have is that when the call reaches the Fax Server - the original dialled number is not coming through so the Fax Server doesn't know who the Fax is for. I've looked at various service parameters and settings but can't seem to get this working.
Any help greatly appreciated.
1 REPLY
Silver
Re: VG224 - Forwarding Dialled Number
Is following the topology:
Fax--FXS---VG224---mgcp----ccm4.0------mcgp----vg224----FXS---Fax
With above topology following would be the configs on VG224 for using Cisco Fax relay
MGCP:
voice service voip
fax protocol cisco
end
mgcp fax t38 inhibit
no ccm-manager fax protocol cisco
no ccm-manager config
Above is with no ccm-manager config. This would allow GW's to do Cisco Fax relay. I would recommend to disable ccm-manager like above config.
Also can they try Fax Passthrough to see if it works.
Following are the passthru configs for both GW's:
voice service voip
modem passthrough nse codec g711ulaw
end
mgcp modem passthrough voip mode nse
90
