VG224 IOS needed
Does anyone have a version of the VG224 IOS.  Mine has gone corroupt and I cannot download a new version from Cisco without a service contract.
This was the version that I was running.
vg224-i6s-mz.124-9.T7.bin
Now all I get is the following when starting my VG224:
Readonly ROMMON initialized
program load complete, entry point: 0x80008000, size: 0x1af1690
Error : compressed image checksum is incorrect 0x38D59F55
        Expected a checksum of 0x51B987C0
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80021220
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041e803
System Bootstrap, Version 12.4(13r)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
FPGA readonly version:00250027
FPGA upgrade version :No upgrade FPGA version present
ReadOnly FPGA currently running
vg224 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
rommon 1 >
I have tried the steps listed in the link below and it did not help.
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
VG224 IOS needed
You will need to open a TAC case for such a request. This is like asking for free music or movies, there is a reason licenses and support is required.
HTH,
Chris
VG224 IOS needed
HTH,
Chris
VG224 IOS needed
Chris,
Thank you for the response.  Do you know how I can format the flash card and install the ios image onto it so that it is reconized by the VG224 gateway.
VG224 IOS needed
You can simply delete the existing IOS by issueing "del slot1 XXXX" where XXX is the name of the file.
Chris
VG224 IOS needed
I am currently in ROMMON mode so I don't have an option to del.  I need to be able to format the flashcard and put an IOS image onto it.  This is what I see under ROMMON.
rommon 19 > dev
Devices in device table:
        id  name
    flash:  internal compact flash
    slot0:  external compact flash
    eprom:  eprom
rommon 20 > dir slot0:
device does not contain a valid magic number
dir: cannot open device "slot0:"
rommon 21 >
767
