VG224 IOS upgrade question
Brent Rockburn
Level 2
Level 2
How do I sprecify the IOS image I want it to boot from.
The current IOS is running out of slot0:
There is no "flash:" whenI do a show flash.
So I thought I could do
boot system slot0:vg224-i6k9s-mz.124-24.T6.bin
however when I do the below command this is what I get and there is no option for slot0:
xxx-x-0x(config)#boot system ?
  WORD   TFTP filename or URL
  flash  Boot from flash memory
  ftp    Boot from a server via ftp
  mop    Boot from a Decnet MOP server
  rcp    Boot from a server via rcp
  rom    Boot from rom
  tftp   Boot from a tftp server
Any help would be great.
Chris Deren
I don't recall if the option shows up under help, but you definitely define it as slot, I though it needs to be slot0 though, i.e.
boot system slot0:vg224-i6s-mz.151-3.T2.bin
HTH,
Chris
Chris Deren
HTH,
Chris
