VG224 MGCP configuration
JUNKSA_2
Dear All,
Can you guide me to configure our VG224 to MGCP protocol and Call Manager 4.x.
Thank you.
Jaime Valencia
The configuration is the same you would use for any other router with MGCP.
There are plenty of MGCP config guides if you search CCO.
java
if this helps, please rate
java
