Community Member
VG224 MGCP Port Configuration
I am configuring a VG224 via MGCP and callmanager 7.0 to support 24 fax machines. I am running into two questions.
When I create the ports should I set them as POTs ports or FXS ports? I'm not exactly sure what the differance is.
Also what exactly do I put in the Attendant DN box? Do I set that to the same phone number as the line I will create?
Silver
Re: VG224 MGCP Port Configuration
When you configure the 224 as MGCP, the CCM option is only POTS. You then configure via CCM page the DN on the line
Community Member
The strange thing is that callmanager 7 actually gives me POTs and FXS. I'll just configure for POTs. Thanks for the info.
463
