Community Member
VG224 Modem communication issue
Hi Guys,
I have a modem conected to a FXS of a VG224 (under mgcp config) where it (caller party) is dailing to other (same manufacturer)in the remote side trou WAN, the issue modems talking but when the caller try to send dtmf digit (log in or password in a system) the called modem seems like is not receiving or receiving bad, the vg224 has the following config
mgcp
mgcp call-agent 10.10.1.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability srtp-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback1
mgcp bind media source-interface Loopback1
Please your suggestions
Andres
Silver
Re: VG224 Modem communication issue
You may try modifying the following paramaters on VG and PSTN gateway: mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
Community Member
Hi Smalkeric
Thanks for your comments.
Do you mean delete the current commands and replace for that you sugguest?
Andres
282
