Community Member
VG224 MWI Stutter Tone Problem
I am trying to get MWI audible indication to work and found it's an issue with the cptone I set.
Being in the UK we need UK tones so set the cptone to gb.  This works fine but I dont get the stutter tone when a voicemail is waiting.
Setting cptone to US the stutter tone works but I'm now left with US style tones
Can anyone suggest a workaround to this or will I have to do without (as the VMWI does not seem to work with any of the handsets we have)?
Green
Hi, What protocol is the
What protocol is the vg224 using  e.g. SCCP MGCP ?
What is the IOS version ?
Alex
Regards, Alex. Please rate useful posts.
Community Member
Hi I'm using SIP with IOS
I'm using SIP with IOS version 12.4(22)T4
I followed the below guide and as mentioned above it works fine when the cptone is set to US but not GB
http://www.cisco.com/c/en/us/td/docs/ios/voice/sip/configuration/guide/15_0/sip_15_0_book/sip_cg-mwi.pdf
Green
Hi,Sorry for the delay.This
This looks like you are hitting bug CSCty92088
https://tools.cisco.com/bugsearch/bug/CSCty92088
It refers to the problem like yours but with STCAPP (SCCP)
but reads very similar.
I think you should try upgrading you ios to 12.4.24T8
Then retest.
Alex
Community Member
Hello That looks exactly
Hello
That looks exactly right!
Unfortunately I don't have a service contract so can't download from the Cisco site.  Where can I get this IOS update from?
83
