VG224 no dial tone on ports
Please help me.
I have CUCM and voice gateway VG224.
The communication protocol between CUCM si VG224 is MGCP.
Yesterday I find that one port don’t have dial tone.
Incomming and outgoing calls is not possible on that port.
Until yesterday this port function properly.
I reload  the VG224 but the problem is not solved.
It’s possible to have a bad port or it’s a bug?
IOS version on VG224 :  vg224-i6s-mz.124-9.T7.bin
Does anyone have an idea about how to solve this problem.
Thanks in advance.
Everyone's tags (1)
Re: VG224 no dial tone on ports
First thing to check is to make sure that the FXS port lists as registered in the CUCM endpoint page.
You also want to watch 'debug voip ccapi inout' as you go offhook and make sure you are matching a dial-peer that have 'service mgcapp' configured on it for the inbound dial-peer match.
If those two things are correct, you should get dial-tone.  If you aren't, you either have something funny in CM like a null translation that is PLARing the port, a bad port, or a cabling issue.
You can watch 'debug vpm sig' to see what is happening on the analog port side.
Hi Steven,
This port (2/16) is registered on CUCM and is working well until few days ago.The phone attached in this port not have dial tone and not ringing.
I attached  the port status and debug messages for incomming calls.
Thanks.
VG224#show voice port 2/16
Foreign Exchange Station 2/16 Slot is 2, Port is 16
Type of VoicePort is FXS
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Analog interface A-D gain offset = -3.0 dB
Analog interface D-A gain offset = -3.0 dB
FXS idle voltage set to high
alt-battery-feed set to feed1
Ring DC offset set to 0 volt
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is active
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
Disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
VG224#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
2/0             --  fxs-ls      up    dorm on-hook  idle     y
2/1             --  fxs-ls      up    dorm on-hook  idle     y
2/2             --  fxs-ls      up    dorm on-hook  idle     y
2/3             --  fxs-ls      up    dorm on-hook  idle     y
2/4             --  fxs-ls      up    dorm on-hook  idle     y
2/5             --  fxs-ls      up    dorm on-hook  idle     y
2/6             --  fxs-ls      up    dorm on-hook  idle     y
2/7             --  fxs-ls      up    up   off-hook idle     y
2/8             --  fxs-ls      up    dorm on-hook  idle     y
2/9             --  fxs-ls      up    dorm on-hook  idle     y
2/10            --  fxs-ls      up    dorm on-hook  idle     y
2/11            --  fxs-ls      up    dorm on-hook  idle     y
2/12            --  fxs-ls      up    dorm on-hook  idle     y
2/13            --  fxs-ls      up    dorm on-hook  idle     y
2/14            --  fxs-ls      up    dorm on-hook  idle     y
2/15            --  fxs-ls      up    dorm on-hook  idle     y
2/16            --  fxs-ls      up    dorm on-hook  idle     y
2/17            --  fxs-ls      up    dorm on-hook  idle     y
2/18            --  fxs-ls      up    dorm on-hook  idle     y
2/19            --  fxs-ls      up    dorm on-hook  idle     y
2/20            --  fxs-ls      up    dorm on-hook  idle     y
2/21            --  fxs-ls      up    dorm on-hook  idle     y
2/22            --  fxs-ls      up    dorm on-hook  idle     y
2/23            --  fxs-ls      up    dorm on-hook  idle     y
VG224#debug voice ccapi inout
Jul 30 12:51:21.488: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x64856F10, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000001647fd8000000F5)
Jul 30 12:51:21.488: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 30 12:51:21.488: :cc_get_feature_vsa malloc success
Jul 30 12:51:21.488:  cc_get_feature_vsa count is 2
Jul 30 12:51:21.488: :FEATURE_VSA attributes are: feature_name:0,feature_time:1692909464,feature_id:542
Jul 30 12:51:21.488: //542/FCF0854E80AC/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 30 12:51:21.488: //542/FCF0854E80AC/CCAPI/ccCallSetContext:
   Context=0x64E1CF20
Jul 30 12:51:21.492: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6449F254, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jul 30 12:51:21.492: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 30 12:51:21.492: :cc_get_feature_vsa malloc success
Jul 30 12:51:21.492:  cc_get_feature_vsa count is 3
Jul 30 12:51:21.492: :FEATURE_VSA attributes are: feature_name:0,feature_time:1692909912,feature_id:543
Jul 30 12:51:21.492: //543/FCF0854E80AC/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jul 30 12:51:21.492: //543/FCF0854E80AC/CCAPI/ccCallSetContext:
   Context=0x64E2EA80
Jul 30 12:51:21.496: //543/FCF0854E80AC/CCAPI/cc_api_call_connected:
   Interface=0x6449F254, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 30 12:51:21.500: //542/FCF0854E80AC/CCAPI/cc_api_call_proceeding:
   Interface=0x64856F10, Progress Indication=NULL(0)
Jul 30 12:51:21.500: //542/FCF0854E80AC/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x64CB6750, Call Id=542
Jul 30 12:51:21.500: //542/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x21E, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 30 12:51:21.504: //542/FCF0854E80AC/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=542
Jul 30 12:51:21.504: //542/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x64856F10, callID=0x21E, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 30 12:51:21.504: //542/FCF0854E80AC/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x64856F10, Call Id=542
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Jul 30 12:51:21.504: //542/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x64CB696C, callID1=0x21E, callID2=0x21F, tag=0x0)
   (confID=0x64CB696C, callID1=0x21E, gcid=0-0-0-0, tag=0x0)
Jul 30 12:51:21.504: //543/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x64CB696C, callID2=0x21F, gcid=0-0-0-0, tag=0x0)
Jul 30 12:51:21.504: //542/FCF0854E80AC/CCAPI/ccConferenceCreate:
   Conference Id=0x64CB696C, Call Id1=542, Call Id2=543, Tag=0x0
Jul 30 12:51:21.504: //542/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xEF, Source Interface=0x64856F10, Source Call Id=542,
   Destination Call Id=543, Disposition=0x0, Tag=0xFFFFFFFF
Jul 30 12:51:21.504: //543/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xEF, Source Interface=0x6449F254, Source Call Id=543,
   Destination Call Id=542, Disposition=0x0, Tag=0x0
Jul 30 12:51:21.504: //542/FCF0854E80AC/CCAPI/cc_generic_bridge_done:
Jul 30 12:51:21.508: //542/FCF0854E80AC/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xEF, Destination Call Id=543)
Jul 30 12:51:21.508: //543/FCF0854E80AC/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xEF, Destination Call Id=542)
Jul 30 12:51:21.508: //542/FCF0854E80AC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6449F254, Destination Call Id=543, Source Call Id=542,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jul 30 12:51:21.508: //543/FCF0854E80AC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x64856F10, Destination Call Id=542, Source Call Id=543,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Jul 30 12:51:21.508: //543/FCF0854E80AC/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9542)
Jul 30 12:51:21.512: //542/FCF0854E80AC/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x64856F10, Call Id=542
Jul 30 12:51:21.512: //542/FCF0854E80AC/CCAPI/cc_api_caps_ack:
Jul 30 12:51:21.516: //542/FCF0854E80AC/CCAPI/cc_api_voice_mode_event:
   Call Id=542
   Call Entry(Context=0x64E1CF20)
Jul 30 12:51:21.520: //542/FCF0854E80AC/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xEF, Call Id1=542, Call Id2=543
Jul 30 12:51:21.520: //542/FCF0854E80AC/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=542
Jul 30 12:51:21.524: //542/FCF0854E80AC/CCAPI/cc_api_call_alert:
   Interface=0x64856F10, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 30 12:51:21.540: //543/FCF0854E80AC/CCAPI/cc_api_event_indication:
   Event=90, Call Id=543
   Event Is Sent To Conferenced SPI(s) Directly
Jul 30 12:51:24.964: //542/FCF0854E80AC/CCAPI/cc_api_voice_mode_event:
   Call Id=542
Jul 30 12:51:33.824: //542/FCF0854E80AC/CCAPI/ccCallFeature:
   Feature Type=34, Call Id=542
Jul 30 12:51:33.824: //542/FCF0854E80AC/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=542
Jul 30 12:51:33.824: //542/FCF0854E80AC/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x64CB6570, Call Id=542
Jul 30 12:51:33.824: //543/FCF0854E80AC/CCAPI/ccGetCallStatistics:
   Call Stats=0x64E2A554, Call Id=543
Jul 30 12:51:33.828: //542/FCF0854E80AC/CCAPI/ccConferenceDestroy:
   Conference Id=0xEF, Tag=0x0
Jul 30 12:51:33.828: //542/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=543, Disposition=0x0, Tag=0x0
Jul 30 12:51:33.828: //543/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 30 12:51:33.828: //542/FCF0854E80AC/CCAPI/cc_generic_bridge_done:
Jul 30 12:51:33.828: //542/FCF0854E80AC/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 30 12:51:33.828: //542/FCF0854E80AC/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 30 12:51:33.828: //543/FCF0854E80AC/CCAPI/ccCallDisconnect:
Jul 30 12:51:33.832: //543/FCF0854E80AC/CCAPI/ccCallDisconnect:
Jul 30 12:51:33.832: //542/FCF0854E80AC/CCAPI/cc_api_call_modify_done:
Jul 30 12:51:33.844: //543/FCF0854E80AC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6449F254, Tag=0x0, Call Id=543,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 30 12:51:33.844: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 30 12:51:33.844: :cc_free_feature_vsa freeing 64E7C150
Jul 30 12:51:33.844:  vsacount in free is 2
Jul 30 12:51:33.856: //542/FCF0854E80AC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64856F10, Tag=0x0, Call Id=542,
Jul 30 12:51:33.856: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 30 12:51:33.856: :cc_free_feature_vsa freeing 64E7BF90
Jul 30 12:51:33.856:  vsacount in free is 1
VG224#debug vpm signal
Jul 30 12:51:55.432: htsp_timer_stop3 htsp_setup_req
Jul 30 12:51:55.436: htsp_process_event: [2/16, FXSLS_ONHOOK, E_HTSP_SETUP_REQ]fxsls_onhook_setup
Jul 30 12:51:55.440: htsp_call_bridged invoked
Jul 30 12:51:55.448: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
Jul 30 12:51:55.448: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voicehtsp_call_feature:feature 24
Jul 30 12:51:55.452: [2/16] htsp_set_caller_id_tx_time Caller ID:FSK_DURING_RING
Jul 30 12:51:55.452: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_CALLERID_RINGING]fxsls_onhook_callerid
Jul 30 12:51:55.452: [2/16] c2400_ring_gen: ring1_cadence_on=250 ring1_cadence_off=500 ring2_cadence_on=0 ring2_cadence_off=0 ring3_cadence_on=0 ring3_cadence_off=0 ring4_cadence_on=0 ring4_cadence_off=0 ring5_cadence_on=0 ring5_cadence_off=0 ring6_cadence_on=0 ring6_cadence_off=0
Jul 30 12:51:55.456: [2/16] c2400_set_sig_state_intercept: ABCD=0, timestamp=0, sys_time=128897173
Jul 30 12:51:55.456: [2/16] c2400_get_ring_cadence: cadence: 2000, 4000, 0, 0, 0, 0htsp_alert
Jul 30 12:51:55.460: [2/16] c2400_get_ring_cadence: cadence: 2000, 4000, 0, 0, 0, 0
Jul 30 12:51:55.460: [2/16] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=128897174
Jul 30 12:51:55.524: [2/16] do_ring_cadence IDLE->ON (2000)
Jul 30 12:51:57.460: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128897374
Jul 30 12:51:57.524: [2/16] do_ring_cadence:OFF request
Jul 30 12:51:58.896: htsp_timer_stop3
Jul 30 12:51:58.900: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
Jul 30 12:52:01.460: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128897774
Jul 30 12:52:01.460: [2/16] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=128897774
Jul 30 12:52:01.540: [2/16] do_ring_cadence IDLE->ON (2000)
Jul 30 12:52:03.460: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128897974
Jul 30 12:52:03.524: [2/16] do_ring_cadence:OFF request
Jul 30 12:52:07.460: [2/16] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=128898374
Jul 30 12:52:07.524: [2/16] do_ring_cadence IDLE->ON (2000)
Jul 30 12:52:09.460: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128898574
Jul 30 12:52:09.524: [2/16] do_ring_cadence:OFF request
Jul 30 12:52:13.460: [2/16] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=128898974
Jul 30 12:52:13.524: [2/16] do_ring_cadence IDLE->ON (2000)
Jul 30 12:52:15.460: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128899174
Jul 30 12:52:15.524: [2/16] do_ring_cadence:OFF requesthtsp_call_feature:feature 34
Jul 30 12:52:16.304: htsp_timer_stop3
Jul 30 12:52:16.304: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_STOP_RINGING]fxsls_stop_ringing
Jul 30 12:52:16.304: [2/16] c2400_set_sig_state_intercept: ABCD=4, timestamp=0, sys_time=128899258
Jul 30 12:52:16.304: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128899258
Jul 30 12:52:16.324: htsp_process_event: [2/16, FXSLS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]fxsls_waitoff_release
Jul 30 12:52:16.324: [2/16] c2400_set_sig_state_intercept: ABCD=4, timestamp=0, sys_time=128899260
Jul 30 12:52:16.324: [2/16] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=128899260
The CCAPI debugs are not complete; we should see an inbound dial-peer match at the top for this call.  I only see the outbound match, so something got truncated.
Also, you typically always want to run debugs together when troubleshooting voice issues, so you can see how the stacks inter-relate to each other.
Having a current router configuration would help.  Since this is MGCP, I'd probably take a look at what 'debug mgcp packet' is doing in addition to the CCAPI and VPM debugs.
Finally, do you have other ports on this device which are working?  If so, you can run the debugs for a good port and compare it to a bad port, to find your deviation.
-Steve Holl
9723
