VG224 not sending Fax
I would like to know if someone can assist me with getting to bottom on an issue I am having.  I have setup my VG224 using SCCP and am getting a dialtone on my fax machine, but it is not sending or receiving any faxes.  I hear the dial tone and fax tone when sending, but nothing is received on the other end.
Config File is below.
VG224#write terminal
Building configuration...
Current configuration : 2605 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service dhcp
hostname VG224
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096 debugging
logging console critical
enable secret 5 $1$tIWN$AH0iMJk21mvCkYfO7yle./
enable password 7 0508075E70495C001D
no aaa new-model
resource policy
no ip source-route
no ip routing
no ip gratuitous-arps
ip tftp source-interface FastEthernet0/0
no ip bootp server
stcapp ccm-group 1
stcapp
trunk group  summary
voice-card 0
voice service voip
modem passthrough nse codec g711ulaw
application
global
  service alternate default
username admin privilege 15 password 7 141E06021F10222E262D2021
archive
log config
  logging enable
ip address 172.20.160.15 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
duplex full
speed auto
vlan-id dot1q 10
  exit-vlan-config
h323-gateway voip interface
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
shutdown
duplex half
speed auto
vlan-id dot1q 10
  exit-vlan-config
ip default-gateway 172.20.160.1
ip default-network 172.20.160.10
no ip http server
logging trap debugging
logging facility local2
dialer-list 1 protocol ip permit
no cdp run
tftp-server 172.20.160.10
control-plane
voice-port 2/0
timeouts initial 60
timeouts interdigit 60
timeouts call-disconnect 0
timeouts ringing infinity
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
sccp local FastEthernet0/0
sccp ccm 172.20.160.10 identifier 1 priority 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
switchback method graceful
dial-peer voice 100 pots
service stcapp
port 2/0
dial-peer search type voice data
line con 0
password 7
login local
line aux 0
line vty 0 4
password 7
login
end
VG224#
Hall of Fame Super Silver
What faxing protocol are you using? Pass-through, relay, NSE T.38?
What is the PSTN GW using?
Chris
At the moment Cisco Fax relay is Enabled.  Pls see attached picture.
voice service voip
Well, the following config:
voice service voip
enables fax passthrough, you need to select fax protocol and ensure the same protocol is used on all call legs, to enable fax relay you need the following:
voice service voip
fax protocol cisco
What is the configuration on the PSTN GW and what type of trunks are you using there?
Chris
In addition what is your PSTN GW hardware as PVDM3s do not support fax relay, see this thread:
https://supportforums.cisco.com/thread/2130357?tstart=0
HTH,
Chris
Chris,
How can I find out what is my PSTN GW.  At the moment I am getting a dialtone and when I send a fax it has the fax tones, but the fax does not go through.  here is the latest config.
VG224>sh running-config
Current configuration : 1963 bytes
version 12.4
no service pad
hostname VG224
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$0GS7$wwKWaoczGa7CB2Xv9fryC0
enable password
no aaa new-model
ip source-route
no ip routing
no ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
voice service voip
fax protocol cisco
voice-card 0
application
global
  service alternate Default
archive
log config
  hidekeys
ip broadcast-address 172.20.160.255
no ip route-cache
duplex full
speed auto
vlan-id dot1q 10
  exit-vlan-config
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 2/0
timeouts initial 60
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
sccp ccm 172.20.160.11 identifier 2 priority 2 version 7.0
sccp ccm 172.20.160.10 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 2 priority 2
service stcapp
fax rate voice
port 2/0
line con 0
line aux 0
line vty 0 4
password
login
end
VG224#
You need to look in CUCM.  You can use Dialed Number Analyzer tool for example which you can find under serviceability page or you can look at the config, do this:
  1. see that Calling Search space is applied to the SCCP port in CUCM
  2. review the CSS configuration and see what paritions are listed
  3. go to Route Patterns and see what patterns are assigned to this partition, you should see patterns such as 9.011! for example for international dialing
  4. See what Route Lists is assigned to this pattern
  5. See what Route Group is assigned to this RL
  6. See what Gateway is assigned to this RG
  7. Login to this GW and post "sh run"
HTH, please rate all useful posts!
Chris
Chris,
1. The calling serach space applied to the SCCP port is the same as applied to all the phones.
2. I do see the correct Route Patterns listed such as 9, 011, 9.911
3. Th Route List assigned is RL_SIP_To_NVT.
4. The Route Group assigned to this pattern are PSTNRouteGroup and RG_SIP_TO_NVT.
5. The Gate assigned it the one that we use for the phone systems not the VG224.
Here is the "sh run" file.
sh run
version 12.4
no service pad
hostname VG224
boot-start-marker
boot-end-marker
enable password
no aaa new-model
ip source-route
no ip routing
no ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
voice service voip
fax protocol cisco
voice-card 0
application
global
archive
log config
  hidekeys
no ip route-cache
duplex full
speed auto
vlan-id dot1q 10
  exit-vlan-config
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no ip http server
control-plane
voice-port 2/0
timeouts initial 60
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
sccp
sccp ccm group 1
service stcapp
fax rate voice
port 2/0
line con 0
line aux 0
line vty 0 4
password
login
end
VG224#
Right,
Please post the config from the PSTN voice gateway.  You need to ensure the fax protocol you are using is consistent on all voice gateways, including the VG224 and the PSTN gateway.
HTH,
Chris
Re: VG224 not sending Fax
Chris,
I don't have access to the voice gateway.  But from looking at the CUCM for both gateways have the following setup.
Modem Passthrough: Enable
Cisco Fax Relay: Disable
T38 Fax Relay: Disable
RTP Package Capability: Enable
MT Package Capability: Disable
Disable
Also when I connect a analog phone, I am able to call a number the person on the other end is not able to hear me.  When I try to fax it starts faxing and then I get a communication failure.  If I call the fax number I get a busy signal and the analog phone does not ring.
Also the Voice Gateway is using the MGCP protocol and the VG224 is using SCCP, it that ok or whould the VG224 be set to use MGCP.
I appreciate the help.
Well, you can clearly see you have only enabled cisco modem passthrough for faxing.  If that is what you want to use then configure the Vg224 for passthrough as well.  If you don't think you fully understand how fax over IP works as that may be challenging to inexperienced folks in this area I suggest you hire a reputable Cisco implementation partner to assist you.
Chris
ok so I setup the VG224 as MGCP and am able to send faxes, but not receive.  when I test sending a fax it says successful, but I do not receive any output.  When I call the fax number, I hear a quick faxtone and then nothing.
Any ideas on what could be causing it not to receive?
Did you read my last post?
You need to ensure consistent fax protocol end to end, and based on your previous post this was not the case here.
Chris
I have modem pass-through enabled on the VG224, see config below.
VG224#sh running-config
Current configuration : 2476 bytes
version 12.4
no service pad
hostname VG224
boot-start-marker
boot-end-marker
enable secret 5 $1$nagz$.0LyyEORmRE9LfCZizayc0
enable password
no aaa new-model
ip source-route
ip cef
no ipv6 cef
stcapp register capability 2/0 modem-passthrough
voice service pots
voice service voip
fax protocol pass-through g711ulaw
voice-card 0
archive
log config
  hidekeys
duplex half
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
snmp-server community public RO
control-plane
voice-port 2/0
timing digit 50
timing inter-digit 50
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.20.160.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.20.160.10
ccm-manager config
mgcp
mgcp call-agent 172.20.160.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip redundancy
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp timer net-cont-test 3000
mgcp timer nse-response t38 250
mgcp sdp simple
mgcp fax t38 ecm
no mgcp explicit hookstate
mgcp fax t38 gateway force
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
port 2/0
line con 0
line aux 0
line vty 0 4
password
login
end
VG224#
VG224#sh dial-peer voice summary
dial-peer hunt 0
TAG = 1
PORT = 2/0
TYPE = POTS
AD MIN = up
OPER PREFIX = up
DEST-PATTERN
PRE FER =0
PASS THRU
SESS-TARGET
OUT STAT = down
I finally got it working.  Able to send and receive fax.  I realized I did not put in a destination pattern, once that was done, everything is working great.
1971
