Community Member
VG224 NumberOfRegisteredGatewaysDecreased + Increased
We have, at many time and every day since 2-3 weeks (since a power shutdown), many messages sent by RTMT indicating that we lost the association between the CCM and 24 gateway (Number of registered gateways decrease).
Few minutes after that, we got a message indicating that we increase by 24 gateway meaning that we are now monitoring again our 24 gateways.
There is the message sent by the RTMT :
At 15:08:45 on 02/01/2007 on cluster StandAloneCluster. Number of registered gateways decreased . Current monitored precanned object has decreased by 24.
At 15:11:47 on 02/01/2007 on cluster StandAloneCluster. Number of registered gateways increased . Current monitored precanned object has increased by 24.
Also, after that message, when we call a fax that is wired to the VG224, we got a "fast busy" tone. Some lines seem to be not available (no dial tone or fast busy tone when we call the line). I reset the gateway from the CallManager Gateway configuration page and everything come in good working order. The problem reapear some hours later and I have to reset the gateway again.
Nothing has been changed on our network in last weeks and the problem seems to be appears after a power outage.
Is someone got a similar problem ? or a solution for this problem ?
Martin
Community Member
Re: VG224 NumberOfRegisteredGatewaysDecreased + Increased
Hi Martin,
We have the same issue here. What IOS version are you running ?
Thanks.
Community Member
Hi Sandy,
There is the IOS running on the VG224 :
Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 12.4(2)T4, RELEASE SOFTWARE (fc2)
Which IOS are you running ?
Community Member
Hi Martin,
We're running 12.3(14)T7.
Bye.
Community Member
Hello all,
Sorry for the long time for the follow up.
We have rebooted the CCM-Subscriber and everything has starting to work good. We no longer get this problem now. May be a corrupted file or association with the VG following some change that we have made on the CCM ?
Martin
1037
