Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VG224 or ATA 186 what is best choice?
I need analogues lines for intercom in LIFT's. (if lift stops and someone is inside press button and a call is made to a number to ask Help).
Also this analogue line will be used by Maintenance company of lifts to monitor status of lift so these type is a data connection.
What is more reliable to choose VG224 or ATA 186 for these two types of conneciton that i need? or are not supported?
Best Regards
MC
Silver
Re: VG224 or ATA 186 what is best choice?
Both are quite reliable. Personally I'd use a VG224 but it depends if you are going to use all the ports on it (if you are only using it for the lifts, is it worth the expense of paying for a 24port gateway?). The ATA's are a cheaper solution.
Generally the ATA's are used for small offices with only a few people and 1 or 2 faxes.
Silver
If it's just one lift in each hotel, have you thought about FXS interfaces?..
This is big resort with many lifts in diferent locations, so my question regard VG224 is the distance beetween VG in DataCenter and lifts around resort (voltage problems...)
My question regarding ATA is that i know for fax it works well but for example for POS(Credit Card payment is not reliable) and Company that will manage the Lift's will do data connections to monitor status of Lift's that is my fear.
MC
I like the VG224 or the FXO ports integrated in the ISR router if I want to continue using the existing wiring. If a data drop (CAT5) is there already then the ATAs work great.
There are also new models of VG coming out VG202 & VG204, with 2 & 4 ports respectively. Found details by accident in the CUCM 7 documentation. http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/gateways.html
Availability apparently late November.
Cheers,
Alistair
509
