VG224 ports giving transient connection
Hello
I have a VG224 in my network which has some ports configured in ccm and some are not part of database.
I see error in ccm as shown:
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 8/18/2008
Time: 10:22:02 AM
User: N/A
Computer: LC-CCMPUB
Description:
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 2000
Device name [Optional].: AN1C58C8F82B401
Device IP address.: 172.16.2.245
Device type. [Optional]: 30027
Reason Code [Optional].: 1
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Node ID: 172.16.1.21
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
Do you think shutting the ports in VG224 will stop those error.
Secondly how to I confirm which ports to shut since MAC do not show up on port level.
TIA!
K
Green
Re: VG224 ports giving transient connection
either configure them in cucm or disable the voice port in VG224
Hey,
HOw do I know which MAC in cucm correspond to voice-port in vg224.
Just do
voice-port 2/1
shut
Silver
Those last two numbers in the device name in the event log are the port number.
You can shut the voice port, or remove the service stcapp from the dial peer, or the easiest thing to do is just configure it in the CallManager - you don't have to assign a phone number to it, just do the basic config. That is the most obvious if you want to use the port later, you don't have to remember to go correct the config on the device.
Mary Beth
Thank you!
Exactly what I wanted
580
