VG224 Recommendation
We are installing a two site UCM Business Edition solution. Main site single gateway will be setup as h323 gateway (due to need to run T.37/tcl scripts - to get faxes to emails).
We also have a vg224 at main site that will have faxes, modem and polycom conference stations off it. My question is, is the easiest way to set this vg224 up is as a sccp gateway registered to CCM? If so, can it still allow modem/fax passthrough? Or is modem/fax passthrough only allowed on h323
setup?
If you recommend h323 for VG224, do I simply point all dial-peers to the h323 main gateway that will have our PRI connected to it? So aside from virtual dial-peers that are created for devices connected, is it just voip dial-peers pointing to the h323 gatway (and not to CCM)? We do want supplementary services for analog phones/conference stations.
thanks in advance,
Silver
Re: VG224 Recommendation
Use MGCP for VG224, faxes work fine then.
regards,
PK
What about modem passthrough? I assume yes but need to be sure.
thank you PK
Silver
For me it worked fine.
regards,
PK
Hello
I'm looking for a config for a VG224 Gateway.
Can anybody provide me a configuration example, for MGCP or SCCP?
I like to configure the easiest way, I think it will be MGCP.
The Gateway will be installed only for Fax Machines.
Thank you for your help.
Pascal
SCCP Controlled Analog (FXS) Ports with Supplementary Features in Cisco IOS Gateways
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html
Configuring the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hello
Yes, it seems to be working fine. I can send and receive faxes.
One last question about QoS...How I need to setup Qos on this Voice Gateway?
Pascal
401
