12-16-2008 10:58 AM - edited 03-15-2019 03:06 PM
We currently have about 20 analog fax lines. I'm trying to see who has had great success with the VG224 using T.38. Our gateways are currently MGCP that support T.38 and I understand the VG224 does the same. The only results that I find when Googling or looking here are people having problems. I'm looking for success stories of those that have implemented VG224's and T.38 for FAX.
12-16-2008 11:48 AM
This should work fine. Generally modem passthrough with NSEs is the easiest to configure, but T38 is a close second.
Here are the command you will need to run T38 depending on what protocol you use to control your VG224:
SIP/H323
dial-peer voice 1 voip / or voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
MGCP
mgcp package-capability fxr-package
mgcp default-package fxr-package
no mgcp fax t38 inhibit (default)
SCCP
Not supported
12-16-2008 12:17 PM
Thanks. Would you say that with things properly configured you can achieve equally reliable FAX transmission as analog lines assuming the network/bandwidth is sufficient?
Also, any particular reason why you opted for CA based T.38 vs. letting the 2 gateways handle the negotiation?
12-16-2008 12:43 PM
Hi Jordan,
Generally once you get the configuration working, things go without problems. There are some corner cases that can be ugly, but that's not much different than any other technology.
You're correct on the CA controlled. It looks like I selected a different grouping of configuration that I expected.
Here's the NSE-based T.38 configuration:
SIP/H323
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback cisco
MGCP
SCCP
voice service voip
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback cisco ( starting in 12.4(11)T)
