Community Member
vg224's analog no dial tone,only buzzer
i am installing vg224 and ccm 5.1,now find something trouble with vg224 that is a few of analog telephone no dial tone only buzzer,i already set the voltage of the vg224 port to "high"(the default is "high" ),follow the runing-config:
stcapp ccm-group 1
stcapp
voice-port 2/0
cptone CN
station-id number 9600
caller-id enable
dial-peer voice 500 pots
service stcapp
port 2/0
please give me some advice ,thanks a lot!
Community Member
Re: vg224's analog no dial tone,only buzzer
i have searched all of the document,but can not find the true yet,it is only my problem?
Try with this IOS vg224-i6s-mz.124-2.T5.bin
Which one are you using?
BR,
Stoyan
Bronze
I haven't used a VG224. I have a VG248. On the VG248 you have to enable the individual ports. You might want to telnet into the VG224 and check to see if the ports are enabled.
Larry
Community Member
thanks for your message,but the circs random appear, not always one port
302
